What's the difference of a '86 mustang block? did 86's come with E7's ? I'd look it up but I'm at school and can't get anywhere. Heard about one for sale locally and I want to start the slow mild build for my '88
'86 Mustang block
E7 means 87, i doubt an 86 would have had themhttp://secondhandracing.com/Home.aspx
the block is ok, but the pistons arent good for anything more than the stock cam......they are flat tops....no valve reliefs
Duce do you have a readers rides or something? I'd like to shoot for times close to yours. what have you done as far as weight reduction? if you wouldn't mind sharing what kind of Numbers are you making without the nitrous?
edit : nevermind found it.Last edited by FastGallopingPonies; 09-18-2007, 09:47 AM.Resident diesel addict
block, rods and crank are essentially the same for 85 up passenger car motors. 86 HO motors use a flat top piston with NO valve reliefs. 86 HO motors also use a E6SE heads, which are the same as the lopo heads and dont flow worth a damn. 86 HO cam is similar to the 87-89 cam but not quite as agressive.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
dont the lopos also have the flat-top pistons without reliefs? if so sounds like if youve got the radiator out of the car it would be a good opportunity to change to the '86 ho cam(maybe without removing any body anels on a towncar, change the dizzy firing order and swap in the '86 ho speed density computer
people knock the e6 heads way to much, they arent great but they arent as bad as people believe. i've seen some pretty badass 86 ho stangs with stock heads and i've even seen a stock 86ho run vs a stock 89 ho, the 86 always pulled on the 89 out of the hole.
stock motor with e6 heads/flattops produce more compression and torque, most people hate them because they dont make the extra 5-10 hp on the dyno but due to the flattops you really have to be careful of piston to valve clearance when changing cams.
"The new heads for the 5.0L in '86 were the redesigned "high swirl" cylinder heads (E6SE casting type). 1987-1995 H.O. motors used truck casting wedge cylinder heads with larger ports and valves, ( casting # E7TE-AA ). They provided an approximate 15 hp increase over the S.O. (E6SE) heads. The S.O. 5.0 used the E6SE heads through '91, while the H.O. engine only used them in '86. The E6 Heads are known for provideing one of the broadest torque bands, especially from an engine with only a 3" stroke"Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
its all about the right setup.
I wanna know what this guys packin.. lol that bitch sounds nasty http://youtube.com/watch?v=1veaear5b4MGive a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Originally posted by Spaz View Postdont the lopos also have the flat-top pistons without reliefs? if so sounds like if youve got the radiator out of the car it would be a good opportunity to change to the '86 ho cam(maybe without removing any body anels on a towncar, change the dizzy firing order and swap in the '86 ho speed density computer
86 pistons are true flat tops.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
The 86 HO cam had less duration on the exhaust side, but a more aggressive ramp, I've actually heard it argued that overall its slightly better than the later HO cam. I don't know how true this is, or really how much it would even matter. Its probably a fairly small difference either way.86 Lincoln Town Car (Galactica).
Originally posted by Tiggie View PostProbably one of the best sites ever: http://www.jason.fletcher.net/tech/s...ons/specs2.htm
http://www.jason.fletcher.net/tech/s...ons/specs1.htm
I don't remember offhand; does "Fletch" mention that the '86 true flattops are still forged, and that they're still good for performance use if you have the time to notch them for a bigger cam? Car Craft did spray their bone-stock '86 shortblock to 650hp (with AFR heads, etc.) after notching the pistons. No carnage whatsoever, even after shooting four-foot flames out the carburetor.2012 Mazda5 Touring | Finally working on the LTD again!
