I have a question about the clutch cable adjustment with a T5 trans. I just helped a friend of mine swap out an A4LD for a T5 in his fox body mustang and we are having some trouble getting enough travel out of the clutch cable. We have the quadrant and pedal adjusted as far as they will reach and we still need more pull on the cable. I can start the car in a gear and get it to move but going from neutral to any gear with the clutch pedal all the way down just grinds. The entire setup is a direct swap from another mustang parts car, all stock components with a new clutch kit of course.
Thanks guys.
Thanks guys.
