View Post
Underdrive Pulley a MUST HAVE for HOs
same crap really. If you can find a 49 or 49 1/2" belt, it should probably be easier to get the belt on. Mine involved removing the lower alternatoe bolt, and loosening the upper bracket to get it together. Actually the 3g with stock pullies could stand a longer belt too.86 Lincoln Town Car (Galactica).
Originally posted by Grand_Marquis_GT View Post1983 Grand Marquis 2Dr Sedan "Mercules"
What's this about having trouble finding a 49" or 49.5" belt? I just walk into the parts house and ask for them, tell them to forget what the computer says I need (usually 50 or 50.5) because it's too long.2012 Mazda5 Touring | Finally working on the LTD again!
49.5" is too long
Originally posted by 1987cp View PostWhat's this about having trouble finding a 49" or 49.5" belt?86 Lincoln Town Car (Galactica).
if you dont have A/C or a smog pump anymore you could get the march pulleys I got for my 351. I'll have to grab a part # when I go back home, was only $45 for the crank and $35 for the water pump pulley, I used the stock alt pulley and no PS pump for now. Everything lines up just fine.
My ma's CV doesn't have A/C and it never will. It does have the smog pump, which I am going to see if I can retain for the Lightning engine. If said underpulleys work without either smog pump or A/C, which alternator can I use if I go with an electric fan and electric water pump?
Originally posted by packman View PostMy ma's CV doesn't have A/C and it never will. It does have the smog pump, which I am going to see if I can retain for the Lightning engine. If said underpulleys work without either smog pump or A/C, which alternator can I use if I go with an electric fan and electric water pump?
Packman86 Lincoln Town Car (Galactica).
i still have my stock pulley's (except for the polished one that came with the alternator), i just reduce the number of pulley's. im at 4 now, gonna reduce it to three whenever i get off my ass and do ithttp://secondhandracing.com/Home.aspx
yes, same pullies were used from about 1981-1991.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyes, same pullies were used from about 1981-1991.2012 Mazda5 Touring | Finally working on the LTD again!
