Alright my '91 is having a bucking problem, It drives fine in 1st - 3rd. but in Overdrive and occaisionally in 3rd it'll buck badly unless I feed it more throttle. if I'm just cruising at around 40-55 and just kinda feathering the pedal to keep speed it'll just buck hard. Any suggestions?
Bucking
needs more tv pressure and keep it out of overdrive below 55 mph
This seams to be the question of the day!89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
the more i read about the frequent TV adjustment issues the more i appreciate that i have the AODE. Sure, i had to replace my MLPS for ~60 bucks but thats been it for 180k (with reg fluid gasket and filter changes). If i ever get myself an AOD equipped car would it be wise to adjust to max TV pressure as soon as i start driving it?
mines done it ever since i owned the car, just keep it in D until you need overdrive and then back to D.
it could also be your tranny mounts are shot making you feel the trans jumping around.
I 've beat the hell out of my car since day 1 while its done this and its still kickin ass..Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Originally posted by Spaz View Postthe more i read about the frequent TV adjustment issues the more i appreciate that i have the AODE. Sure, i had to replace my MLPS for ~60 bucks but thats been it for 180k (with reg fluid gasket and filter changes). If i ever get myself an AOD equipped car would it be wise to adjust to max TV pressure as soon as i start driving it?86 Lincoln Town Car (Galactica).
All better guys, grommet of course crumbled couldn't find one at any of the auto places so I picked up a pack out wire grommets for the time being until I can get over to a deaership and try and get a brass one. moved the slider up bout a 1/4 of an inch maybe 5 or so notches, shifts aren't real firm but no more bucking and the car accelerates better now, also found my #6 cyl wire off of the plug not sure if I did it or if it's been like that. she seems to run nice now.Resident diesel addict
