I got alot done on the '84 today, even if it did rain... sort of did it between the showers... hardest part was trying to line up the holes on the trim pieces, while trying to start the screw with the drill gun, while trying to hold the whole mess up! (And doing it blind, as you couldn't see the screw holes....)
Here is the "completed" pictures....
The insulation between the back seat and the trunk.. it is now twice as thick as original... Added another layer of "jute" insulation, then wrapped the whole thing in plastic... Looks sort of tacky, but it's about a full inch thick now!
Got the sunvisors back in... they look really good... These were also fun to put in!!!
The rear seat in... had a hard time getting the seat to clip over the hook, due to the extra insulation... but at least it isn't coming off!!! I also put another layer of the insulation under the back seat... Hope it makes the car alot quieter!
Another shot... A HATE the way the flash makes the interior look "purple"!!!
Well tommorow I start wiring all the emergency equipment, running all of the wiring harnesses.. so I can get the center console installed, and then get the front seats back in, followed by the cage, gunrack, and other "goodies"!! I also have to remove all the seatbelts, and have them cleaned... then re-install them.. I realized today that they needed cleaning BAD!!! I also have all new plastic "trim" pieces that go on the buckles... Tom....
