Pushrod question
    Pushrod question
    Ok so when I do my HO conversion is it ok to use the stockers or will they be too long for the HO cam? I didn't know if I needed the pushrods off a HO either or not.
    Thanks.
    I believe the stock pushrods are just fine...but I'm only 94% sure.
      If in doubt, get an length-checking adjustable pushrod to make sure. A local speedshop in Lansing, MI got me a Comp Cams piece for about $23, and it goes from 5.8" to 6.8" and is even calibrated 0.050" per turn.
        Same stock pushrods. HO and non-HO used the same length.
          Thanks alot guys. Thats what I needed to know.
