I have an 82 LTD with a carbureted 302. New alternator and new external regulator. The car drives fine until I turn my head lights on. then the car sputters at 50% throttle or more. Moreover, the more voltage I use (A/C, wipers) the worse it gets. any suggestions??
302 low voltage
302 low voltage
Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
sigpicTags: None
Check your voltage when you are having the problems.
Check your battery cables and make sure all connections are good and clean. All connectors to the alternator should be clean as well.
The next thing that comes to mind is a weak coil.1990 Country Squire - under restoration
Forgot to add, YAY another '82 LTD! Pictures Pictures Pictures!1990 Country Squire - under restoration
I dont think the forum would like the pictures.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Oh, the coil and the ignition control are new.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Sounds offhand like excessive resistance in either the headlight circuit or the charging circuit, perhaps as simple as a corroded connector, perhaps as annoying as a large handful of badly chafed wires. There's got to be something in there putting excess load on the charging system when the lights are on.
Tiggie, I think it's highly unlikely, but do you know of any reason the Duraspark II module itself should be involved in these symptoms? Like maybe for some dumb reason there's only a normal system voltage drop going on but the module just isn't liking it?2012 Mazda5 Touring | Finally working on the LTD again!
make sure the altenator is charging.....should be at least 13 volts at idle.....could be a bad wire somewhere put the headlights on see what the voltage drops to
Will check, Thank you. Oh, How do you think the forum would feel about a Pontiac / Ford LTD hybrid?Vehicle: 1965 Pontiac Catalina (fastback 2+2)
I second the alternator and battery cable idea. If there was that much of an excessive load from the lighting system, wouldn't a fuse give out?Nick
88 Colony Park LS
Originally posted by 82LTDQS View PostWill check, Thank you. Oh, How do you think the forum would feel about a Pontiac / Ford LTD hybrid?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 82LTDQS View PostWill check, Thank you. Oh, How do you think the forum would feel about a Pontiac / Ford LTD hybrid?**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
For some reason, I cant post a long reply with the car's info. I will keep this short and start a new thread. Thanks for the interest guys.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
I promise to get good pics loaded soonVehicle: 1965 Pontiac Catalina (fastback 2+2)
Originally posted by 82LTDQS View PostFor some reason, I cant post a long reply with the car's info. I will keep this short and start a new thread. Thanks for the interest guys.2012 Mazda5 Touring | Finally working on the LTD again!
