Hi All, I am new to this forum as well as to American cars.( any car actually!) I am an expat physician in Saudi Arabia and just bought a 1988 GM Colony Park wagon from a friend in fairly good condition and with 180,000 km on the clock.Single owner. A few problems have surfaced lately:
1. Engine seems to be missing slightly, noticible as a vibration when the AC and/or headlights are switched on. Less in 'Park' position, more evident in R and D. Started suddenly a day ago.
2.Occasionally stalls at traffic lights and while reversing to park, etc. Been happening for some time. I read that the Idle Air control may be at fault. Would this be the case ?
3. After the oilpan gasket was changed recently due to a long standing leak, I had the underbody and engine compartment pressure washed. After this the ' Check Engine' lamp flickers red at idling RPM, and disappears at higher RPM's. Not seen all the time but usually manifests after driving 60 KM or so. Never happened before the car wash.
4. There is steering wander especially at highway speeds. On my mechanic's advice I changed the tie rods and Idler arm and got the wheels aligned and the steering wheel centered. The wander is still there. I was then advised that this was due to rear suspension and sway bar bushings. Would this be correct ? There is an occasional 'clunk; from the rear of the car after going over a speed bump.
Please advice on what to do. I will be taking the car in to a garage for computer codes shortly as soon as I can locate the Ford Service Center here.
I am attaching a picture of the engine, Can someone identify the labelled parts please,
Thanks
Thanks
