After getting the Windsor put in my car, I went to hook the throttle and the tv rod back up. But I think that little threaded stud that comes out of the transmission that the tv rod bolts to got pushed into the the transmission and now it won't come back out.
AOD tv rod problem
what is this factory 4bbl from?
no
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Going from limited experience here, but I would think that you could use the rod if you can fabricate a little linkage to go on the side of the carb and get the geometry somewhere near right.
A 68 Linc is prolly gonna have a 4300 Autolite. It would also have the auto trans provision, but that doesn't help anything when you are running an AOD.
We need pics mang to see how you got the rod to work. It is possible, given that the rod is being pushed back right behind the throttle lever. But we need pictures to see. I'd like to use a rod when I convert to 4-bbl.1990 Country Squire - under restoration
If you can get the geometry right, and the rod will clear the intake, there really is no reason for it to not work. Mostly the problem is getting the geometry correct. Basically you'd need to take measurements of the stock cfi unit and get the distance from throttle shaft center to the center of the hole for the TV rod and compare it to the measurement from throttle cable to throttle shaft center. Just make the ratio the same on a 4bbl and you're good to go.86 Lincoln Town Car (Galactica).
I drove the 85 with THIS for a TV rod for FOUR YEARS (ghetto adjustment set by feel)..!!!
I think you will be ok
