My '88 has been chirping off and on for over a year, now.
It usually it starts when I have to drive through deep puddles during a heavy rainstorm. It always stops, sooner or later. It seems to help if I turn on the A/C.
I'm almost positive the noise is coming from the A/C compressor.
It first happened when I over tightened the belt.
Since its only occasional/temporary, I'll live with it until something breaks.
You might try spraying some lubricant in the A/C clutch, both in the front face and the small gaps in between the clutch, pulley, etc. on the compressor. Use the little red tube and be very careful not to get any lubricant on the belt or pulley.
And do not use spray belt dressing on a serpentine[flat] belt.
