idling crappiness
    idling crappiness
    Sorry to bug you guys again, but I'm at a dead end with very similar problems to the ones i had a while back when I posted.
    My standard '85 CV idles for shit, and the stalling at low RPM's is ridiculous. I replaced my TFI module, distributor, ignition coil, plugs (gapped at .50), plug wires, fuel filter, ECU, thermostat, engine coolant temp sensor (the car was running a tad hot... that's fixed now), and O2 sensors, while adjusting my timing back to the 10 BTDC it oughtta be at. Still, it can't idle worth a shit. Stalls and dies at low end, and pours black smoke out the muffler. My cats and muffler clogged due to this, so i replaced them, too, although with the embarrassing stock single exhaust. Can't seem to make any progress with a terribly rich mixture, either. Anything I should check that tends to be a common issue that deals with low end stalling?
    Thanks in advance.
    Check the vac line at the MAP sensor along with the sensor itself. IIRC, when they go bad they go bad in a direction that causes your car to run rich...
    '80 Town Coupé
      aha... will check that tomorry.
        fuel filter, pump, regulator also can cause issues. Same with a stuck injector.
          I'm also going to go with vacuum problem or bad MAP. They don't fail all that often though, so a cracked line is more likely.
            Yes a bad line to map. Black smoke, stalling, idled for shit. Do you get any codes?
              He has a CFI, does those have a MAP?
              2000 Grand Marquis LS
              Mercury Owners Group member
                Yes. I think its on the fender on a CFI car though.
                  where is my map sensor, exactly? no codes, for now. my friend borrowed my code reader. i'll get back to you on that one tomorrow or so. i'll also check the vacuum line tomorrow. thanks.
                    'twas the MAP sensor. thanks, guys.
