Will the stock valve covers fit over the 1.7 crane roller rockers I put on if I remove that oil baffle on the passenger side. I know they seal well and I'd rather not buy another set off a mustang because they seem to go for upwards of 50 dollars most of the time.
stock panther vc's on 1.7 rr?
the crane rockers like they used on the mustang cobras will fit
i have the blue motorsport rockers, they are a little taller, they wouldnt fit
Really? Because my stock TC valve covers wouldn't clear my Cobra (Crane) 1.7's, they weren't even close to clearing......... But I'm running "The SUPER MYSTERY (probably an "E") Camshaft!!!!!" So that's possibly why.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by mrltd View PostThe panther valve covers are 93-95 Cobra valve covers....1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
They sure as hell look like the early Cobra cover. The late Cobra cover looks exactly like the Panther one, with COBRA stamped into them. They're one of the few sets of covers that clear under the SN95 intake, so they're sort of desirable in that crowd.86 Lincoln Town Car (Galactica).
OK, now, I got a buddy of mine to measure his SN95 valve covers (he has a 95 GT), and they were 2" tall on the short side, 2.5" tall on the tall side. My TC covers are ~1.5-1.75" on the short side and 2" on the tall side.
I will add that when I tried to put my TC covers over top of my 1.7's, they literally sat like 1/2" off the head or so (could be exaggerating a bit here, but they definitely were sitting ON the rockers, not touching the heads), sitting ON the rockers. As I said, there wasn't a snowball's chance in hell of them fitting. That's why I had to scrounge up a set of the cast aluminum Mustang ones.Last edited by OVERKILL; 08-08-2007, 12:39 AM.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
odd. usually the stock panther ones will clear while the stock cast Mustang ones will not.86 Lincoln Town Car (Galactica).
yea i've ssen broken ho valve covers from roller rockers
Originally posted by gadget73 View Postodd. usually the stock panther ones will clear while the stock cast Mustang ones will not.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by gadget73 View Postodd. usually the stock panther ones will clear while the stock cast Mustang ones will not.http://secondhandracing.com/Home.aspx
OK guys I just put them back on today, I tested them first by placing them on the engine without gaskets and there was no sign of contact at all. I tapped the oil baffle out of the way a little bit just in case.
DO roller rockers go higher and higher at high RPMS? or do they rock and roll the same distance at all RPMs?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
