Ok, in dealing with my ongoing no start condition, I just verified that there's no power going to the coil in my Turd. What are some possible causes of this? Someone told me it may be the TFI, or it may be the ignition control module. Any thoughts or input would be greatly appreciated.
No power to coil?
Everything else has power. I used a voltmeter and put the positive on the red wire and the neg. on the inner fender as a ground, with the ignition in the "on" position. That's the correct way to test it, right?Nick
88 Colony Park LS
It's probabaly the connector on top of the coil, the one with the red and green wires. Most likely corrosion in the connector or in the wires close to the connector, probabaly less than 2" back from the end. Take off the connector, cut the wires and put new female connectors that have blue sleeves on the new ends of wire, and slide those on over the two connector tabs down inside the coil connector on the coil. Try it then, it'll probabaly have power.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by Mercracer View PostThe inner fender is plastic. Use a good ground on the engine or a good body ground.Nick
88 Colony Park LS
Originally posted by nfldfordltd View PostIt's probabaly the connector on top of the coil, the one with the red and green wires. Most likely corrosion in the connector or in the wires close to the connector, probabaly less than 2" back from the end. Take off the connector, cut the wires and put new female connectors that have blue sleeves on the new ends of wire, and slide those on over the two connector tabs down inside the coil connector on the coil. Try it then, it'll probabaly have power.Nick
88 Colony Park LS
Chase it back farther and look for a break in the wiring. A bad TFI will not cause the red/green to not have power. That wire should run around to a connector somewhere on or near the firewall, probably over near the brake booster. On a Panther its a grey connector laying right next to the cruise. Unknown on an MN12. It will be the connector over there that the fuel pump wiring and all is in, should have about a half dozen wires. Check the voltage on both sides of the connector. I'll bet either the connection there is bad, or your ignition swithc took a dump.86 Lincoln Town Car (Galactica).
