modular air intake systems.
    Explore replacement air filters, cold air intake systems, air box intake kits, custom accessories and more, factory direct from Spectre. Join our legacy of performance.
    I'm going to buy some later this week to make my own intake system. i would just like to know if anyone had any experiance with this modular air intake systems. and what parts did you use to make one.
    http://www.cardomain.com/ride/2681604 --- http://www.supermotors.net/17596
    There are a few member's who have built there own or used one made for another car, like an Integra or something. As long as the intake tube is the same size as the TB or bigger, it won't be as restricting as the stock intake tube. Check out Gadget's engine(top of every page), or MeLikeyStripperChick's TC, or Custom87 built a badass cold air intake kit for his car. Monty also has a CAI, I think.
      http://www.grandmarq.net/vb/showthread.php?t=12495 here you go. One of the first threads I started here too.
        fancy website.....looks expensive......ebay is where i shop....and home depot
          Actually Spectre stuff isn't too crazy expensive .... a lot of that stuff is probably on the shelf at your local AutoZone.
          Personally, I think the modular intakes are a semi-cool idea, provided they're fairly sturdy when assembled.
            k i just bought all the parts i need today and there on my car right know. i used 60degree elbow then straight 6 in tube and then 22degree elbow and the filter of course there all 3" diameter. theres some pics on how it turned out. MAN ITS SOUNDS BEUTIFULL. thers a video as well but i dont know how to load videos? and also DO I NEED A BREATHER ???? you know the very small filter.
              The sounds from my digital camera really doesnt get the sound that it really makes. its much deeper. anyways if you have panther like mine and you want to ma...
              k the sound is muuuch deeper then my digital camera recorded. anyways it sounds SICK!
              (i tried the youtube thing and it doesnt work for me. all i see is a white box. so sorry you have to open another window to see it)
                To use the youtube brackets, you enter in only what's after the = sign. For example, (YT)2szTh8dtErU(/YT) (I used your vid for example of what goes into the brackets), except you use brackets, not parenthesis. Get it?
                BTW, I don't think the camera does it justice.
                  it was kinda hard holding my camera and pushing the gas pedal at the same time. and thaxs 88Vic!!
                  http://www.youtube.com/watch?v=
                    You can just use the throttle cable under the hood, makes it a lot easier.
                    And you're welcome mang, glad to help.
                      PVC PIPE!
                      1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
                      FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
                        man know i feel like a retard. but hey we learn new things everyday. but still
                          Originally posted by 87vicFIVEO View Post
                          PVC PIPE!
                          dude that will be kinda cool though. ghetto intake system.
                            Ask scott about the PCV based intake he got for 20bux on ebay. It's funny.
                              What breather are you talking about, the line that goes from the throttle body to the oil fill tube? Yes, you need that, if only to keep the holes all plugged up to keep it from sucking unfiltered air.
                              Oh, and dump that stock airbox bracket. It looks a bit silly under the new intake.
                              What did it end up costing you? I'm going to be in need of creating some sort of new intake system for my car when I get around to doing the mass air setup.
