Radiator Removal
      The rental fees on those cranes are a bitch. Im glad Ive only replaced one radiator, at least I put an aluminum one in.
      -Matt
      1968 Fairlane 500 - 1998 Camaro Z/28
        Originally posted by ButtSlappingPirate View Post
        Don't believe anything the rest of these guys tell you. You are going to need an aerial crane, sorry.
        Any particular sort?
          You could probably get it out with just a Sikorsky S64E Skycrane, but I wouldn't go any smaller than that.
            Just a S64E? Okay, could be worse .. that's pretty doable:
            Question, though: do these have kewl cockpits with dozens of gauges everywhere you look?
              This is deja vu...
                I was thinking the aerial crane you see on building jobsites...20 stories high...
                  Of course! What helicopter doesn't?
                  I recommend you practice removing the radiator on some junkyard cars before you try it on yours, as learning how to handle the collective and rudder properly to take out a radiator requires a small amount of practice. It's an easy job once you get the hang of it. Good luck!
                    Dunno .... if I built a helicopter, it'd probably have something dumb like a speedometer and a Check Engine light, maybe a fuel gauge and tach, and probably not much else. Of course, if I built a helicopter, it's not likely it'd ever get off the ground ....
                      So... if you built a helicopter, it'd be a car?
                        Well, considering cars are all I know about ........... yeah, it'd probably just be a really funny-looking car.
