Can anyone tell me what the voltage values should be on a 82' Mark VI? i believe my TPS has gone partially bad. Comming back onto throttle from coasting it will after a few seconds hesitate abruptly. Under WOT, it just bogs.
Things that i know are right:
Fuel pressure at WOT 42 psi (this is TBI remember)
tune is fine
timing is lined up with #1 perfectly
That should be of some assistance if anyone has had the same problem with a TBI based system.
Like i said, i have played around with adjusting the TPS and it does help, but not entirely (since i have no volt meter to test, and ARE NOT MECHANICALLY INCLINED AT ALL REALLY).
Help help help!!
--Len
tune is fine
Help help help!!
--Len
