i just sent of my 302 block to the machine shop, going .030" over on it, and grinding and balancing the crank.
now, i'm trying to build an everyday driver here, please keep that in mind.
what cam selection should i go with? what would be a good cam that provides very smooth idle, to say... 5,000 rpm?? also, what ratio rocker arms? should the stock heads just be reused after a valve-job? should i stick with the stock intake? are the injectors going to need to be upgraded?
any help is appreciated
thanks,
andrew
thanks,
andrew
