hello gentlemen, well last week on july 4th i decided to put on some new front rotors/discs on my cv. while under there i noticed i was missing my emissions box. dont know if thats what its called or not(little black box with two hoses connected to it, located directly underneath the battery) but it wasnt there anymore. apparently my battery was sliding around too much, cut the hoses that went to the box and one bump to many led to its downfall. now im not too worried about this but was wondering if i should. hoses are just there hanging, havent gotten around to pluggin them. what do you guys suggest?
emissions box missing...
it will still run ok... note you mpg fix it if you want to spend the $$$Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
It won't hugely affect anything, other than you'll smell gas fumes. There is a vacuum line to it, but it only gets vacuum when decelerating normally. This can possibly make the car stall when you come to stops and stuff, and isn't going to help your fuel mileage any. Might as well replace it, any box will have one.86 Lincoln Town Car (Galactica).
It could also dump gas fumes under your hood and that can't be a good thing!89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
