I'm rebuilding my '88 Town Car and want a better rear end that will bolt right in. It must have disc brakes and trac-lok, and I'd like 3.55's, but I don't know how easy it will be to find a K code. I am flexible in the gearing department, depending on how easily I can find what I want and for how cheap. What other codes are there that have trac-lok and disc brakes that might be easier to find, and what year Panthers would I find them on?
What year Explorers had the intake that is very similar to a GT40 intake?
I'd like to do the 3G upgrade. Which vehicles can I get direct bolt-in/plug-in alternators from?
What vehicles can I get an electric fan from? I realize just about any 12v automotive fan will work, but I'd appreciate it if someone could point me in the direction of some fans that will fit my radiator and brackets the easiest, with the least modification required.
I've finally found a junkyard whose employees are actually helpful and am trying to take advantage of that fact as quickly as possible. Any help would be greatly appreciated. Thanks!
