Well I just got done fixing the coolant CTS leak and Anabelle is back on the road. There is still a hairline leak of coolant somewhere in that area. I will be taking it back to the shop that welded my intake for a spot weld. (it leaked about 2 teardrops worth) The air intake charge? sensor is now in the intake pipe, and the car seems to bog down from 2k-3k then liftoff after that, but even after the Exploder intakes, 1.7RR and 65mm tb I don't feel a whole lot power. Still gotta put my equal lengths and straight pipe on tho, and new plugs. Could she be running rich with the sensor being moved?
post-rebuild quirks
post-rebuild quirks
Originally posted by 89LincolnTWNcar View PostWell I just got done fixing the coolant CTS leak and Anabelle is back on the road. There is still a hairline leak of coolant somewhere in that area. I will be taking it back to the shop that welded my intake for a spot weld. (it leaked about 2 teardrops worth) The air intake charge? sensor is now in the intake pipe, and the car seems to bog down from 2k-3k then liftoff after that, but even after the Exploder intakes, 1.7RR and 65mm tb I don't feel a whole lot power. Still gotta put my equal lengths and straight pipe on tho, and new plugs. Could she be running rich with the sensor being moved?
You still running the lopo cam, ecm and 14lb/hr injectors?1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
he did an HO cam and injector swap.
You might want to swap the 60mm throttle body back on there just to see if it helps. It should bump the air velocity up a little and help out some with the flat spot.86 Lincoln Town Car (Galactica).
Ahhhh, so Mark VII ECM then eh?1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
yeah lemme give a rundown for those who don't know
19lb 4 hole injectors (just got new ones!)
1991 Mark VII ECM
1991 Mustang HO cam
65mm TB, Lightning EGR spacer
1997 explorer upper and lower intakes
AC delete
smog pump delete
stock mustang headers
stock mustang catted h-pipe
E7TE rebuilt heads stock spec
82,000 miles on block and internals
cheapest copper spark plugs from autolite
Parts to go on:
Electric fan (stopped working...again..)
BBK equal length headers
Off road H pipe
Scott - PM me a price on a 60mm TB modified with townie lever. Mine was cut up to mod the explorer one..1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
So yours is basically identical to mine except for the cam thenI ended up converting to MAF due to a rich issue that was directly related to the low vacuum condition caused by whatever friggin' camshaft I have. BUT, when it was SD, it would pull like a bear with no noticeable dead spots that I can remember, other than it idled like crap and richer than all hell........
I'm still running the 60mm TB, I figure stock E7's don't need a 651989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
60mm for teh win I think, I idle hot at 1200-1500 rpm in Park1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
that sounds like a vacuum leak if it idles that high. That could definitely cause flat spots.86 Lincoln Town Car (Galactica).
I found out what it is, the throttle body is sticking open just a tad, because the way they welded on the lever, it doesnt snap back to the stop, but if I touch it, it idles correctly. SO I need a 60mm tb with a townie lever. Anyone got one?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
yeah, sticky TB butterfly will do that, actually I sometimes have to have mine open like that cause my IAC sucks hardcore and sticks closed so if a smack with a lugnut pipe wrench don't help I pull the plug and open the TB manually with the stop screw, can you say idle at 400rpms when in gear with A/C and everything electrical on?
i can make one up......running low on lopo throttle bodies tho, and ez pull wants 25 bucks ea
cuz it was broken, and I have no money to fix it with, cuz I'm in college. I have two fans that keep me cool enough. soo much has changed, I really need to update the pics in reader's rides. Stay tuned!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
