fan query
    mark and taurii fans have 3 wires. all you really need is the fan itself. i looked into using one of the stock controllers, and its got tie-ins to all sorts of nonsense. much easier to use an aftermarket controller that doesn't need input from the ecm and vehicle speed sensor, and other junk like the taurus one does.
      I use the Mark VIII fan on my TC as well, but I only have the low side hooked up to the sensor probe, which is more than enough to cool my modified engine. That fan moves SERIOUS air! I am running a 3G Mustang 130A alt.
      1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
        Just the other day I sat in my Mark VIII idling with A/C cranked for a half hour in 95 degree temps (large blacktop parking lot) with no ill effects. It really must move a ton of air.
          mine actually makes no apparent difference between low and high speed, or at least I couldn't tell. It does move a lot of air though.
            Low side only draws 20A or so running, where as the high side draws at least 30A, and the CFM difference is something like 3,200 on the low side and 4,xxx on the high side.
              never hooked it to an ammeter, but there is no difference at all in noticeable air output or sound levels. other fans have a very distinctly different sound between high and low, but not this one. dunno, sometimes junkyard finds aren't exactly perfect.
                True, but that's where mine came from too
                  Thanks, for the fan info!
