CTS leak
    CTS leak
    Hey whats the best way to seal up that pesky coolant temp sensor on the lower intake, its spewing all over the place, even though I put tephlon on it.
    I'd try some liquid thread sealant...it's white goopy stuff in a rubber cement type bottle that you're supposed to use on head bolts when they go into the water jacket. We used that on a 318 a few years ago and it worked great. Go to the auto parts store...they oughtta have it there.
      Just use plumbing tape. It seals perfect, won't go bad with age, and doesn't make a mess either.
        He used plumber's tape.
          I got that white goo you mentioned and hopefully that will do it, but now I have another leak on my hands at the back of the lower intake manifold
            pipe tape only works if u wrap it going the way u would that when u loosen, so wrap ur sensor counter clockwise and cover ur starting point. that way when u thread it back in it wont undo itself. a couple more wraps may help aswell. if not id check for damaged threads or cracks. if all else fails try some RTV sealant
            1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
              teflon tape is good for leaks........gotta use the paste
                Just dip the entire engine in white goo. It'll never leak anything from any orifice ever again lol
                  That's a lot of white goo.
                    Which, I think I need not remind you, is PRECISELY what she said!
                      When she finally ditched you and fucked yer roommate instead? :evil:
                        Dude...that's creepy...were you there or something???
                          Me? Nah, I just know how that goes, seeing how when I was still in the dorms I usually ended up being kicked out to the couch in the living room so that roommate can get some sleep while Michelle was doing her best to scream the whole floor awake. Speaking of which, heard anything from my Canadian friend lately, you know, the blonde cutie that used to live straight across the hallway from you?
                            ROFL
                            You've combined three girlies into one, my friend. There was one that lived across the hall, one from Canada, and one that was the blonde you were actually interested in. But they're all different people lol
                              Damn, now I feel lucky my dorm roommate was a homosexual!
