I just picked up a upper and lower intake manifold off a 97 mountaineer. the intakes have the egr provision. I also nabbed the injectors. I noticed that they are the 4 port spray nozzle.
I couldnt grab the heads as the exhaust manifold bolts were stubborn bitches and also the fact that the front bumper was where the water pump was. making removal of the accessory brackets impossible.
i got 2 questions. can the 4 port injectors from the mountaineer be used in a ho conversion using the foxbody ECM's? or they useless without the mountianeer ecm?
2ndly. since i have the intakes and they are equipped with the internal egr provision will they work with some worked over e7's? egr and all? or is there aftermarket i should look into that would be a better match to the intakes ablity? unless i can find a pre 98 set of GT-40's im going to have to use e'7s or something aftermarket.
