Hey guys, any of you on here have nitrous on your panther, or on your HO converted panther more specifically? I was considering it as a cheap way to get to 350hp fast when I want to.
nitrous on HO conversion
Originally posted by ButtSlappingPirate View PostIs this an actual HO engine, with forged pistons? If it isn't, you really don't want to try nitrous on a cast-piston engine, especially a CV/Lincoln lo-po 302.
i was spraying 125 on hypercraptastic pistions with 16* of timing, stock plugs and 87 octane, nothing happened to my motor, but i would not suggest doing that because it is risky.http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalf View Postwith non-forged pistons just stay under a 125 shot. you need a fuel system that is in good working order, a stock fuel pump will suipport 350HP, much more than that and you are gona need more fuel flow. also need to pull 2* of timing and go two heat ranges colder on the plugs, also 93 octane fuel is a good idea.
The timing, and plugs are not necessary until the 100hp levelhttp://secondhandracing.com/Home.aspx
Originally posted by MeLikeyStripperChicks View PostWell if you do that, how will the engine perform when the nitrous is off, as in regular city driving?
That's the cool thing about a switch chip or a tweecer. You can have different tunes and select what you need for what you are doing. IE, pull timing when running N20 and add fuel, have normal timing and fuel when normally cruising.Builder/Owner of Badass Panther Wagons
