Whenever I get on the gas at like 3500rpm there comes a rattling sound from*I think* the drivers side row of rockers. I have not yet installed my 1.7 roller rockers so that might fix whatever it is, just wondering what it could be so I can fix it while I'm in there.
top end rattle at 3.5K
have you checked the engine oil level lately?
the noise could be any number of things... pull the valve cover and inspect everything.
Justin had a rocker arm break on him one time.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Stock engine? Probably a valve floating issue :-P"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Could even be bearing noise. Not unheard of.86 Lincoln Town Car (Galactica).
I have noticed what seems to be a bottom end rattle at startup on cold mornings, but it goes away when she warms up, but this is definately coming from the top end of the motor1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
A.K.A Kaptain Kanuck, Your Connection To The Great Land Of Eternal Winter and Incredibly Rusty Cars
- Oct 2006
- 2083
- Ontario
- Send PM
My 90's engine sounded like a can of marbles was being shaken under the hood once it warmed up. I was thinkin it was a dead lifter, but could only hear the noise through the stethescope when i stuck it under the back of the upper intake on the right hand side and got the tip of it on the intake manifold. You can use a broomstick to the same effect. start up your motor, have someone hold the rpm at the desired level, and go along the valve covers and see if the noise increases in any one spot along the entire length of the cover. You could also check your oil pressure with a gauge, but you gotta pull out your oil pressure switch and install the gauge. If oil pressure is low, could be the cause of your rattle. Could be many many things.sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
Vic's Reader's Rides Page http://www.grandmarq.net/vb/showthread.php?t=16917
Vic's Cardomain page http://www.cardomain.com/ride/2532949
1975 Chevy C-10 Cardomain http://www.cardomain.com/ride/3371894
piston slap? what is that? I think it is a rocker arm that is not torqued down enough, and its hitting the valve cover.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
basically its the pistons flopping in the bores. The skirt smacks the cylinder bore and makes a noise. Usually it gets quieter when the motor warms up because the pistons expand a bit.86 Lincoln Town Car (Galactica).
Originally posted by 89LincolnTWNcar View Postpiston slap? what is that? I think it is a rocker arm that is not torqued down enough, and its hitting the valve cover.
You might be suprised...1983 Grand Marquis 2Dr Sedan "Mercules"
well, I pulled off the valve cover and everything looked fine, I checked the torques on the rocker arm bolts and they were all to spec. I went ahead and installed the 1.7 RR on the drivers side. I have some questions about the explorer lower intake, as there is no hole for a sensor that is present on the towncar lower. Ill post pics later.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
ACT, air charge temperature sensor. Extend the wires and stick it in the airbox. Problem solved.86 Lincoln Town Car (Galactica).
