I need to replace the oil pan gasket - and the valve covers, but on the oil pan, you know there is a cross member that runs right over the pan and I was wondering if it would be ok to torch the crossmember off then do the pan gasket then weld the cross member back in.
Seems alot easier than lifting the motor up.
Penny for your thoughts on this matter.
