I put on the explorer TB
    I just got the towncar bracket welded onto it this morning, so I installed it because I wanted to see if it would work. She is now idling hot at around 1200rpms and when put in drive, the car gives a good jerk. I notice the TV pressure is up a bit as well, as now the overdrive kickdown is around 42mph with no throttle whereas it was like 38mph. Seems to have more pickup. Anything I can do about the idle?
    might need to reset the ecm to deal with the new TPS setting, or just drive for a while, it'll re-learn it.
      What EGR spacer are you using?
        I have a lightning in my garage, but right now its the bored out lopo.
          Bored out lopo is smaller than the TB. why bother? It's probably got a leak because of the mismatch.
            bah mike......i have a 65mm tb with a bored lopo spacer......it dont leak......not saying brians doesent leak
