I noticed today my car only got up to 180 on the way in. It's usually is closer to 190.
Will a thermostat go slowly?
They can get sticky and either not close or not open properly. If its original, its probably due for replacement.86 Lincoln Town Car (Galactica).
Thanks, I am planning some tuneup stuff soon, so I will add that.2000 Grand Marquis LS
Mercury Owners Group member
Stick with the stock thermostat, around 194*. My 302s always ran best in that range. If you go with the 160* stat the computer will keep dumping fuel trying to get up to temp.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Thanks
Will a higher or lower tend to cause detonation? When I first got her she'd ping on uphills before it would down shift. I bumped the timing some that cured that and recently I adjusted the trans to downshift sooner. I need to recheck my timing, but need to get a timing light again.2000 Grand Marquis LS
I believe if it runs too hot it can cause detonation, but let one of the others with more experience (Mike, Scott, Johnnie, etc) chime in on that.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Excess heat can make it ping, yes. If your car has a tendency to run hot you can use a 180 tstat but I wouldn't go any cooler. The motor actually wears less at warmer temps believe it or not.86 Lincoln Town Car (Galactica).
It has never been hot since I added the gauge. I think it probably has to to with the CFI running lean at WOT that was discussed in another thread. I just want to tune it the best I can to maximize my gas mileage.2000 Grand Marquis LS
