Idle problems with ho upper
    hey mangs scott just installed my ho upper yesterday he fixed the idle problems last night before I drove home. this moring I drove to the doctors and the car is idleing high. when scott fixed the idle problems before I left. He took the plate that goes under the iac off and he noticed that the my ho upper had a tiny hole
    on the throttle plate so he to a tiny screw and some locktite and screwed it in.
    also we had to use a different tps because my old one would not fit the ho throttle body would that effect the idle or the iac.
    have any of you mang had problems with your ho upper upgrade with idleing .
    thank mangs for any input
    shit i forgot to set the tps......i feel like an eediot!.......trying to get u mangs done last night in time
      Gabe.... you're in school to be a mechanic, right?
      so fix it already.
        I don't have a volt meter to fix the tps
          Well then, now's a good time to get one
            Have you reset the ecu? That tps voltage stuff really isn't that big of a deal, the ECU learns around it. MIght be a vacuum leak or the actual idle screw needs adjustment.
              no we did not try that I'm not sure the idle screw did not do much for the Idle probley need to reset the ecu maybe what I really need to worry about is my trans
