yep, up until 1996. 300 cubes of stump pullin fun. Had no problems spinning all 4 tires in the snow, and got a good 4 wheel chirp in the dry. I think they are rated at 20 more horses than our 302's. And that with only a big one barrel carb. Plus, they easily make 300k before a rebuild, and about 18mpg.
EFI Fuel Injectors
Yeah, the 300 I6 in an F250 with a manual trans is a super stump puller. Slow as hell in low gear but they'll pull anything. Huge amounts of torque, all at low rpm. Excellent engine for towing. No speed demon but they're very reliable. The low operating RPMs is part of why they last so long.86 Lincoln Town Car (Galactica).
I got the car moving, today, and it doesn't shake as much when put back into park as it did before. Just rode it up and down the driveway since it's not registered and all that crap. And it didn't shake as much. What the hel is going on?
Originally posted by gadget73 View PostYeah, the 300 I6 in an F250 with a manual trans is a super stump puller. Slow as hell in low gear but they'll pull anything. Huge amounts of torque, all at low rpm. Excellent engine for towing. No speed demon but they're very reliable. The low operating RPMs is part of why they last so long.
How's the mileage??1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
maybe. it is one of the primary sensors for controlling fuel mixture.86 Lincoln Town Car (Galactica).
Originally posted by 86VickyLX View PostI got the car moving, today, and it doesn't shake as much when put back into park as it did before. Just rode it up and down the driveway since it's not registered and all that crap. And it didn't shake as much. What the hel is going on?
my 86 does the same thing, its not in as nice of shape as your car but it still runs like a raped ape. since your cars not registered im guessing you dont drive it much but you sometimes start it up wherever its currently sitting?? these cars tend to do this on a cold start it might go rrrrrr rrrrrrrrr rrrrrr and stumble a bit for a couple seconds or less. try letting the car just sit running for a while until its fully warmed up then give it hell around the block a few times, come back and see how it idles then..
have you reset the ecm lately by disconnecting the battery or ground?? maybe thats your problem or maybe that will solve your problem.. either way you have to be driving it and letting it reach full operating temperature before you complain about shaky idle problems. if the batterys been disconnected your computer needs to relearn things that cannot be done by simply driving down the driveway..Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
