Vacuums
    Vacuums
    While chatting with a friend's dad...My car was brought up and it came to my airhorns and how I want a larger compressor and tank and all...
    He said that cars around the 80s had vacuum lines that led to nowhere, and that I need to hook my horns to that.
    Is there any vacuum hoses in my car that I may be able to hook the horns to? Sending 25 psi to them just doesn't make 'em loud enough.
    Uh, but the horns work off PRESSURE....Not Vacuum....
    get a bigger compressor or put a small tank that you can keep charged up. I remember seeing setups like that on some train horn website.... They sold all the parts to put the train horns on cars.
      Yeah, okay, I thought that was a little weird.
      I already know what I'm going to get. A small compressor and tank from Wolo that delivers up to 110 psi; instead of my direct drive 25 psi piece of crap.
        there is a HUGE vaccuumm line atached to the throttle body, use that
        1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
        FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
          j/k
            yar, vacuum and pressure are exactly the opposite, and there are no "lines that go nowhere" on these (or really any) cars. Some 80s cars, especially ones with carbs, had a zillion lines that sooner or later would get disconnected from some "useless" part, and thus end up with a random line but EFI Fords dont really have all that many vaucum hoses.
              your friends dad is a moron. tell him we said to stay away from your panther.
                those horns would relly "suck" then
                  :stupid:
                  BUT in theory it should work, like breathing (inhaling) through a harmonica
                  i mean airflow one way= airflow the other right???
                  kinda?
                    air horns work by vibrating a membrane though. it wouldn't work in the opposite direction. One could design one to operate on vacuum I guess but the way they work normally it would probably just suck the diaphragm flat and thats about it.
                      I said in THEORY mang
                      lol
