getting sluggish
    getting sluggish
    my car is relly starting to get sluggish,,, it had lots of get up and go a few weeks ago, but now she is relly slowing down, if i floor it from a stand still it just boggs right down and some times pops out the carb, and if im driving and need to speed up ill kick the pedel down a bit and it justs boggs down before slowly aceclerating, before if i did that it would just get up and go, and before if i stood on it from a stand still it would lite up the tires, it has new wires and cap, (well a few months old) and i put the plugs in almost a year ago, the coil is a supper stock accel,
    the engine dosent knock, and only has 170,000 kms on it,
    Accelerator pump going bad? The entire carb could probably use a rebuild.
    You need to get an another 4V intake!
      timing? Carb adjustment? Choke sticking?
        time to adjust your points, dood
        LTD is still here
          He doesn't have point, you fuckin' tosser!
            yea i aint got points buddy...
            i fixed it alredy just advanced the timming a bit, works a lot better now
              its a fuckin joke you dingbat. :SMACK:
              LTD is still here
                Good deal. I was getting annoyed with sluggishness for a while, and found my timing had somehow bumped itself back to 6 degrees, when I'm certain I'd originally set it at at least 10. Now it's back up at 12-14 degrees and feeling great.
                  Timing on my '82 sucks. I've advanced it as far as it can go without hitting the intake/water neck and I've only got 10 degrees. I think it was factory installed a tooth off, the factory wanted it at 8 degrees on my car.
                    Sounds like it's time to pull it out and install it a tooth advanced, and retune!
                      I should do that. Dunno why I haven't already, guess I am lazy.
                        Aren't we all ............
                          yea thats what i did when i had my dizzy out a while back
