carb question
    carb question
    soo.... question...
    i've been looking at carbs to swap onto the 351w from fordman which hopefully sometime soon the paypal issue gets worked out so i get the engine.
    but anyway back on topic... i was looking at edelbrock carb/intake combos and i was trying to figure out which would be better to get? the single quad or the dual quad setup?
    Gotta give more details...how are you building the engine up otherwise? Heads? Cam? Compression ratio? Stroker engine? Desired use (i.e., street or race)?
      For a stock 351W a single 4bbl carb will be enough. Only a stroker or majorly modded 351 will need dual carbs.
        i'm not completely sure what is going to be done yet. I'm definitely planning on a cam, the car is going to be street, occassionally taken to the track but it will not be a daily driver. I'm going to be going for the old-school muscle car feel and sound.
        I want to try and get as much hp and torque out of this block as I can without blowing the bank. Definitely want to cam it, possibly bore and stroke
        not sure about the compression ratio or the heads that are going to be going on it yet... any opinions on how that should be set up?
        i'll be going for a pro-street like feel but won't be cutting the hood to stick a blower on top, but i love really lopey engines so thats what i'll be going for
          "Really lopey engines"=very aggressive cam=no low end torque=slow Panther.
          From what you're saying in general, it sounds like a single 4bbl will be fine. Two is way too much for anything but a seriously built engine given the number of cubes you're working with.
            ok... when i was talking it over with fordman he kept referring to the carb as a 4v carb? what's the difference?
            and any suggestions on performance parts for the engine would be awesome.
            I was also looking into equal length headers into an H pipe to dual flowmasters... what companies make products for my application? I was looking into bbk but it seems like they only work with shorty headers for the mustang 302s?
            EDIT: almost forgot.. i'm planning on 4.10 gears in the rear end
              4V carb=4 bbl carb
              2V carb= 2 bbl carb
              It's basically Ford's way of designating carbs as far as I know. I don't know of any other manufacturer that refers to them as "V".
                4V=4bbl or 4 barrel carb
                *Edit* Nate beat me to it.
                As for exhaust, no one makes exhaust specifically for these cars, you kinda have to make it yourself. BBK unequal length headers to an offroad H-pipe(2.5" will work well since you plan to mod the engine) and Flowmaster mufflers(offset/offset) will work great with you car. You can have turndowns after the mufflers or you can get Impala SS over the axle tailpipes.
                  Definitely go single 4-bbl.
                  Dual quads are really needed on anything these days except for pro-stock and top fuel cars running 6's and under in the 1/4 mile. Dual quads look awesome, but they are expensive to buy and maintain.
                    The 351 I am going to use came out of a mid 80's bronco and stock on that engine was a 600cfm carb so something that size or slightly larger should work with the engine and some mild mods well.
                    -Matt
                      The 'v' actually stands for 'venturi'. It honestly makes a lot more sense describing a carb by how many venturi it has than barrels. Barrels are used to carry oil or make whiskey. What exactly they have to do with a carburetor is beyond me.
                        yea, a sing 600cfm carb will do just great!
                        *CFM=Cubic Feet a Minute*
                        but I would look on forums and Ebay for a good used one.
                        I bought a Holley 4160 (600cfm, 4bbl, electric choke, vaccuum secondaries) for $70. and that came with the rebuild kit.
                        here's a few pics of it, in case you're curious:
                        and my Edelbrock Victor Jr Intake...it was recommended by Turbo(he and his buddy ported my Heads)
                        more pics of my parts waiting to go in here:
                          does anyone here use barry grant products?
                            The carb on my 408w is a 784cfm Pro Systems unit. Custom 4150 built/tuned for my app.
                            '80 Town Coupé
                              hmm ok.. so the edelbrock intake/carb combo i was looking at would be more than what i would need... i was looking at this combo:
                              part: #20344
                              its an 800cfm carb
                              also has anyone done a cobra-like exhaust?.. meaning.. running the exhaust from the headers down the side of the car under the doors and out right before the rear tires?
