getting a ping in 3rd and 4th gear under load. started after i adjusted the timing a 2nd time (first time i set it to 10* but it had a vac leak i capped off) from TDC (0*)
power is excellent and i even backed it down to 9* but still get a ping.
just cheapo gas? running 89 octane. i wirebrushed the heads and pistons when i did the HO junk so no carbon deposits.
BTW scott you were right about the timing. mine was at 0* when i checked it initally. had much more power even after the 1st adjustment, runs excellent now.. still slow)
