will explorer intakes alone make power?
    If I just stuck on my explorer intakes with the lo-po bored out EGR and 60mm tb, would that be a waste?
    It'll flow better than the stock HO....Don't know if it'd be worth it though.
      yea...it would almost be like a bottle neck effect I would think...
        you might gain a few ponies but the bottle neck would just move from the stock upper to the stock heads. plus you would probably loose torque due to the reduced velocity because of the larger runners. I would not do it unless you have the parts to accompany the intake. E7 heads at least...
          I've decided to sell the intakes, they are in the for sale section
            put it on
              oooo put them on and later up grade to Mass air too and then later port the heads .....do you allready have HO? if not put that on the list too! Rock on
                do I have HO!!??? Of course I do!
                I WOULD be putting these on if I could find a Lightning EGR spacer, but they are impossible to locate. I've had 3 people pm me that they have one and never PM me back on Lightning forums.....
                  just modify a mustang spacer for christs sake
                    Ok I'll try that. Im guessing drilling and tapping, then inserting studs into the tapped holes will do it.
                      Fuck drilling and tapping, just use a regular Mustang spacer, any EFI Mark VII accelerator and cruise control cables, and a 3.8 EFI T-bird TV cable - works like a charm, especially if you take the extra effort of oiling the cables.
                        hmmm, I've never changed TV cables before, or even looked at how they are attached down there, this will be a new venture for me.
                          One bolt actually attaches the cable jacket to a bracket at the trans, and it just pops off at the lever on the trans, pretty much just like the throttle cable. Very simple. The down side is the backwards cables look messy (in my opinion anyway)
