speedo gear
    Orange 20 tooth for 3.55 gears with a 7 tooth transmission. Purple 23 for 3.55 and 8 tooth. I've had both transmissions in my car with a 3.55 rear gear.
      How about for 4.10's what speedo gear do you need for them and where can you get it?
      1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
      FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
        Chart says purple 23 for an early AOD. You can get one at any Ford dealership for about $8. If you've got a late AOD, then you're somewhat SOL. Ford doesn't make such a gear, and you'll have to check around for an aftermarket solution. They don't hold up real well because the teeth are so finely pitched, and you'll pretty much be chunking a speedo gear every 10k or so.
          Justin, from what I was told, you would want the Orange gear...
          I bought one for my car, I just havent gotten it in yet...
          I dont have jack stands and I dont trust being under the car with a "scissor" jack holding it up...
          I got mine from mustangsunlimited.com...ran $9...when I get home, I'll see if I still got the part number for it...
            And then you have the weird trannys like mine with weird speedo's. The only way I got mine correct was was to use a 17T gear and it's still about 3MPH slow.
            That's with 3.08's. Even that has been questioned lately. I used the procedure of jacking up the rear wheels and turning the driveshaft, the theory being a little over three turns of the driveshaft should equal one turn of the rear wheel with 3.08 gears. Of course, I turned the driveshaft and one and a half turns later the wheel had made a full revoltion. Obviously, I don't have 1.50:1 gears. One wheel turned, the other was stationary. Stay tuned as my 8.5 rear turns out to be a worn out traction lock equipped 3.42 (quite possibly a dealer installation since it was a towing package car and a dealer demonstrator) and my mystery tranny ends up having a 6T drive gear even though no such thing should have existed.
              Keep in mind that in a differential when you prevent one wheel from turning, the other will spin twice as fast. So 1.5 turns of one wheel is the same as 3 turns of both wheels--you've got 3.08s, mang.
                Well that makes since now. Crap I want 3.42's or 3.55's .
                [/thread hijack]
