Lookie what I just found...
I guess my 351 swap would look a lot more stock then...
manifold adaptor 351/5.0
[11-82010] $99.00
Broncos has come up with an adapter that will allow you to use the 351w lower truck manifold and the car 5.0 HO upper manifold. This will allow you to put a 351W with EFI under a stock steel hood in your Bronco. comes with two gaskets and all necessary hardware. This is a true bolt-on fix for your hood and firewall clearance problems. Plus you may gain a little horsepower.
[11-82010] $99.00
