Car shut off in Park, common culprits?
    Could be the EGR, but unless you know the TPS is good, it could be opening the egr because it thinks the TPS is in a cruise position. TPS controls a lot of stuff, so it's always good to make sure it's not bad first.
    Ah ok. Didn’t know the TPS had its hand in that many pockets. The weather is crappy this weekend so next weekend I’ll pull the EGR off and clean it and also test the TPS.
    Is the EGR valve supposed to be spring loaded closed? I do remember putting my smoke hose onto the little vacuum port on the side of the valve and I watched the diaphragm shoot forward. I thought that was weird that it would move under positive pressure.
      Update: the weather cleared up slightly so I had some time to look into some things. I removed the EGR valve and inspected it for cleanliness/functionality. While there was some carbon buildup, I don’t think there was enough to cause the pin to get hung up (see image). I put negative pressure on the vacuum port (in a old fashioned way) and verified that the diaphragm moves the pin and returns it to the close position with a strong spring force…ok…so not a valve issue it seems.
      Next I went over to the control solenoid and popped the cover off. I didn’t see anything obvious but someone on a foxbody forum said that occasionally these can seize up, so I gave it a quick blast of silicone lube. The foam filter disintegrated as I went to remove it so I cut some new foam and stuck it in there.
      After all this I fired up the car and let it idle for about 5 minutes, then went from Drive/reverse to park about 10 times with no issue. No stumble or anything.
      So I think that this is an intermittent issue with the aforementioned TPS or the IAC, just my theory.
      As far the the 34 code goes I think it might be a red herring…
      I’m gonna do some research on testing the TPS. It looks like you just need to back-probe it with a multimeter.
      I will keep this updated. Thanks for the help so far!
      You may only view thumbnails in this gallery. This gallery has 1 photos.
        If the EVR solenoid was sticking, it could cause the EGR to hang open, so if the car doesn't act up any more, the shot of lube may have sorted it.
          Fingers crossed Sly. I have a TPS in my cart on Rock Auto just in case..
          Just some food for thought. Would disconnecting the battery cause the car to “relearn” some functions like the newer cars would? Reason I ask is because this started happening after I had the battery disconnected while replacing the window gears. I wonder if I didn’t do proper drive cycle and confused the EEC..
            Yes, it would relearn, but unless the idle is mechanically set too low, with the throttle stop screw allowing the throttle valve to close too far making base idle way too low, it shouldn't ever get close to dying as the IAC will open plenty to keep it running even if it's set a little too low. I doubt that is the issue since it dies when you remove load (put it in park) since this problem would be when in drive.
              This just popped into my head, maybe it’s relevant here. When I did my KOEO test I didn’t get the 11/111 code. All it got was the 34 code, 10 (continuous memory), then 34 and that was it.
              Edit: this is irrelevant. The lack of a 11/111 code means that there was a stored code. (I’m new to OBD1 lol)
                34 is sometimes an EGR position sensor problem, but it can be a nugget of crap under the valve preventing it from closing, or a bad EVR causing the valve to get vacuum when it should not. Since you've verified the valve is OK, unhook the vacuum line from it and see if anything changes.
                  I did try this. The line going to the valve had no vacuum on it, however I did this while the car was idling normally and not loping.
                  Along with testing the TPS, I plan on doing a KOER test to see if that yields anything.
                    Update: drove it around today in 85* FL heat and the car acted normally. Not gonna rule out that I fixed it quite yet. I’m still suspecting the TPS. I will be away this weekend so I won’t have time to test it. Until then I really appreciate everyone’s responses! It kills to have knowledgeable people around when it comes to these old barges.
                      I had a bad TPS in something that coded. Any time I came off the throttle it would hitch and buck. Voltmeter said dead spot right near closed throttle. It had a code about TPS below min voltage so it wasn't real hard to figure out. One "new" one from the pile of random used Ford parts fixed it.
                        Now that you mention it.. I do feel a slight couple jerks when I coast at like 35-40MPH, usually happens right when you let off the throttle then goes away.
                        Did the code show up during a KOEO reading?
                          Yes. It also kicked on the check engine light, but most boxes don't have that. This was on my old Mark VII but same engine controls and such. CEL wasn't steady-on, just whenever I let off the throttle.
                            Semi long-term update: since my last post the car has been behaving as it should, goes into park just fine. I checked my TPS and it’s set at 1.07V at closed throttle (maybe too high?) and seems to have a smooth sweep throughout the throttle travel.
                            Would’ve liked to have a definite answer on what caused this to help others out who will have this issue, but I guess this mystery will go unsolved until further notice haha.
                              Since you cleaned and lubed the EVR, I would say that was the issue. Now it's not sticking and functioning properly.
