For sometime, my car has been running very rich with loss of power, stumbling, and misfires.
I have replaced the following,
-Upper plenum gasket
-PCV valve and screen
-endless vacuum lines
-MAP sensor
-throttle position sensor
-EGR valve
-fuel pressure regulator
-spark plugs and tune up
-fuel pump
-fuel filter
-smog/air pump
-IAC valve
(added fuel injector cleaner to gas as well)
I recently did a smoke test to look for vacuum leaks. only leak I observed was smoke emanating from a metal pipe that crossed over the transmission bell behind the back of engine, but I think that’s the air injection pipe that sends emissions to the cats so I don’t think that’s affecting the operation of the motor (pic below). No other leaks observed.
OBD I reader is giving me code ‘32’ which is a bad EGR I believe (pic below). But that was replaced with no improvement, unless the new EGR is bad?
i’m thinking maybe bad fuel injectors? I’m running out of ideas. Thanks for any pointers .
-MAP sensor
-EGR valve
-fuel pump
-fuel filter
-smog/air pump
-IAC valve
