its just some connector number which I forget, but those two are what interface the main ECM harness to all of the sensors and actuators on top of the engine. The fuel injectors, throttle position sensor, EGR sensor, IAC, etc all run through there.
if you're in that general area looking at wiring, find the orange wire coming out of the harness that runs down to the oxygen sensors and male sure it is still bolted to the rear of the intake manifold or the back of the head. Thats the sensor ground wire for all of those engine sensors in the block and things will go goofy with it off. Pretty common for the eye to crack. Just put a new crimp eye on it and put it back on. Usually it will be one of the rear corner studs on the lower intake, the one with an extra nut on top.
