Originally posted by friskyfrankie
View Post
5.0 Idle issues
yeah its not a tool most people need often unless you're doing HVAC work on the regular. I own one because I found it for 20 bucks at the flea market. Its been used maybe a half dozen times in as many years.86 Lincoln Town Car (Galactica).
I've used the air bypass one maybe 6 times... but I had to monitor the supply air and do it in segments, shutting the valve between to let the compressor catch up. I did manage ~23 inHG with that setup. The cheap electric vacuum pump will pull 28 if you just leave it for half an hour or so. I've used that one 3 times now. Much easier to deal with. It's a single stage pump though. But yeah... not many uses for sure.
I bought the Venturi “pump” because I thought it would be sufficient since I’ve seen other people use it for ac systems. I’m just gonna take it back and get a refund for it. I’m also gonna see if I can get this drier warranty replaced since now it’s been exposed to moisture for far too long. And I don’t think I have a leak any where I replaced all lines and fittings. But I’ll go rent a 2 stage vacuum pump from somewhere as I don’t see myself having to use one frequently
I would not take the PO's word as gospel. You need to PROPERLY vacuum down the system - AFTER REPLACING ALL THE REQUIRED PARTS, for at least 30-45 minutes and see if it hold vacuum. Some folks try to do these jobs half ass and live to regret it.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostI would not take the PO's word as gospel. You need to PROPERLY vacuum down the system - AFTER REPLACING ALL THE REQUIRED PARTS, for at least 30-45 minutes and see if it hold vacuum. Some folks try to do these jobs half ass and live to regret it.
You can always check with your local auto parts store and see if they rent decent units (they'll want a deposit) so you don't have to buy one if you can't afford or have a future need for one.
Originally posted by monotonorobo View PostI forgot to mention that my new r134 pressure switch for the drier got crossthreaded when I put it on somehow. The old r12 switch doesn’t have an issue and I remember you told me that you kept the old switch during your conversion. How would I go about adjusting the old switch if I install it on the drier? Or would I need to adjust it at all?What I Own: 1993 Mercury Grand Marquis GS
Unplug the electrical connector
stick a screwdriver in there and back it out about 1/4 turn. it should turn off around 20-25 psi. I think the R12 one shuts off about 25-30. There is nothing magical about the R134a switch, its just set to a slightly lower cut-out pressure.86 Lincoln Town Car (Galactica).
I only suggesting trying to get the OEM switch as that would prevent the need to keep messing with the screw hoping to get it correct. If it is not available, then yeah, one could try adjusting the screw until it is correct. All that being said, the part is still available.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostI only suggesting trying to get the OEM switch as that would prevent the need to keep messing with the screw hoping to get it correct. If it is not available, then yeah, one could try adjusting the screw until it is correct. All that being said, the part is still available.
