5.0 Idle issues
    If those bolts holding the manifold onto the compressor are stripped in the body of the compressor, pretty solid bet its going to leak from the O rings under there. They need to be clamped down properly.
      I think he meant the heads are stripped.
        Yeah it was the heads
          ah, that makes more sense. Have seen things be gorilla tight into aluminum with bad results though. Doesn't take a whole lot to rip the threads out.
            I’m back out here today and trying to get the compressor off, got all bolts and nuts except for that one nut that sits towards the top of the compressor bracket on the pulley side. I don’t know how any of you have gotten it off.. I would be able to just pull the compressor but that thread for the nuts on the bottom right side is stopping me and I’m contemplating on cutting it off
              I wouldn't cut it. IIRC, it's just really long and there's spacers to keep track of. You may need to take the radiator fan and shroud out for clearance. If it touches the radiator, you may need to take the top brackets off the radiator to lean it forward just a bit to get that last thread of clearance.
                I think I can get it now, I found my 1/4” to 3/8 adapter and I’ll try again tomorrow since it’s getting dark already. I would’ve had a much easier time did I could get the bracket that the smog pump is connected to but bolt that’s on the bracket is probably the tightest bolt I’ve ever tried to break.
                  Yeah... having the right length socket/extension really helps in that area.
                    Can't quite picture what you're having issues with. I just had all that off my car a week or so ago, none of it gave me any grief. I don't remember if I used a wrench or a socket on that top bolt but it was definitely nothing special. I think I used a 3/8 ratchet for every bolt on the front of the engine.
                    The one bolt on the smog pump is a long SOB, goes all the way through the smog pump, through a spacer, and into the engine block. Lots of spots for corrosion if thats what you're fooling with.
                      Yeah I couldn’t break the smog pump bolt loose yesterday and so I couldn’t get the bracket that covered the bolt off. I was able to break it loose today but it took all day to get it. I also had to move the ignition coil bracket out the way for space. Still can’t see it because of the picture but I can at least access it now. I tried to break it loose with a 3/8 and an adapter and snapped the adapter in the process. I’ll get a picture tomorrow and show u what I’m talking about before I take it out
                        You shouldn't need to remove the bracket to get the compressor off. I don't think you're trying to work on the correct bolt.
                          Maybe. I’ve never seen someone remove the whole bracket but I’ve also never seen someone with this thread stuck in the bottom to the bracket. Every bolt that holds the compressor to it is off, all 4 or 5 of em. When I was talking about cutting it off earlier, I meant the thread not the bracket. https://youtube.com/shorts/txtiI5VOE...KSgRE4y3oog7dT
                            Ah... so someone put the bolt in backwards. That's a real pisser. Can you not wiggle the compressor loose in the rear and just slide it back as you rotate it to slide it out? That is a horrible place for that. That tab on the compressor is actually threaded, so the bolt won't slide out.
                              Wut, that's a stud there? Mine has a bolt in that spot.
                              Since you got some access now, can you double-nut the stud and thread it out the front?
                              2005 Volvo V70 Bi-Fuel
                                Yeah I knew it was threaded..
