No start?
    No start?
    Hey guys. I'm hoping to get some advice on my '87 GM starting issue. So right now I have interior lights on but get nothing from starting the car. After trying to start the car, it doesn't try to turn over and the lights go dead. It takes removing and putting the battery cable back on to get the lights to come back on. I've tried the tap the starter trick to no avail and the battery is fully charged. Do you guys agree it's time for a starter replacement? Any tips on replacing the starter? Thanks everyone
    @Ryan.Madison68
    Weak battery causes that self-protect relay trip you're dealing with having to disconnect the battery to reset it. I've never found that mechanism on my cars though. It's not related to the starter though the starter may be showing its age. Definitely test the battery first and make sure the cables have good connections to the battery and the starter and engine block.
      sly I think you're right. I tried to start it with my battery pack jumper majiggy, and it started up fine. Strange thing is before that I took it to Auto zone. They tested it and it showed the battery as good. Thankfully the battery is still under warranty. I'm going to get a replacement next week.
      On another note, I tend to pull the negative cable off at night due to a slow electrical drain that I have yet to find. Does leaving the positive cable on without the negative for an extended period of time have an effect on the battery?
      @Ryan.Madison68
        No
          more likely a crappy battery cable or crusty connection. These aren't smart enough to have any sort of low battery protect relay or anything of that nature.
            What's the cutoff relay that sounds like a mechanical timer then? After about 30 seconds it would stop and lights would come back on. (I might be remembering a GM vehicle now that I think about it)
              I had a starting issue like that, it would only fire if I put the jump box on and the battery was fully charged. It turned out to be my crappy positive battery cable. I replaced that and cleaned up the posts and negative terminal and tightened everything and no issues since.
                As I have often said, look for the easy stuff first.
                  never heard that before
                    Must be a GM thing then.
                      Thanks donkeylips I'm going to try that. Do you all know what kind of cable the positive wire needs to be (gauge, etc.)?
                      @Ryan.Madison68
                        at least 6 gauge. 4 would be better. Some folks even go with 0. Don't really need more than 2 gauge I don't think unless you're running some obnoxious audio system.
                          Update: So it's back up and running. Here's what I've replaced. Battery, positive battery cable and starter solenoid. My thought is that it was a faulty starter solenoid. It's been the 3rd or 4th possibly 5th one I've replaced since owning the car. Is that typical for other panther owners?
                          @Ryan.Madison68
                            Yes, unfortunately. Not sure about the standards these days, but with every single panther or late 80's to mid 90's Ford truck I owned, that was the first thing I swapped out for Motorcraft. Although that's probably not what it once was. I was used to the things welding themselves closed circuit and the starter just spinning away as a result.
                              no that isn' normal. If you're eating starter relays, you probably have a dying starter.
