HO pcm
    HO pcm
    What pcms are compatible with the 302 HO firing order and have the built in cruise for a 91 Grand marquis?
    88-92 Lincoln Mark VII is the usual choice. Speed density, integrated cruise, no wiring harness changes required.
    just be aware that speed density can get pretty bitchy about anything other than stock engines, so if you're planning modifications you may need to tune it and much of the Mustang / Ford ECM tuning knowledge tends to be for the mass air ECMs. Those have gotten to be dumb money though.
