The cruise control doesn't work on my 85 Gm, you guys got any pointers as to where to start diag?
Cruise control
Check the cruise vacuum switch, pull off the line from the cruise servo that goes down and into the cab. It should hold vacuum, if it doesn't, try lifting or wiggling the brake pedal.
You can also try lifting on the brake pedal why trying to engage cruise control while driving. There's also an electrical switch on the brake pedal that could've come out of adjustment.1985 Mercury Grand Marquis LS, "Maisa"
2005 Volvo V70 Bi-Fuel
nope. The vac dump valve is different plumbing.
does the horn work? If not, the buttons for the cruise don't have any power and it won't work86 Lincoln Town Car (Galactica).
This is the section from my 84 Continental EVTM. Same system used through 1987 on the Panther cars but the connectors are probably numbered differently. Only real difference, the connection where it says 'from electronic instrument cluster' comes from the VSS. On the digital dash cars the VSS goes to the cluster first.
this is where I'll yet again mention that having an EVTM for your particular car is a really good idea. I've become something of a document hoarder, any time I find some sort of factory manual for one of my cars that I don't have, I buy it if the price isn't stupid. The EVTM and the body/chassis/electrical manuals are by far the most useful but I've ended up with full wiring diagrams, radio service manuals, and EEC/emissions diagnostic manuals that have been useful at various points.86 Lincoln Town Car (Galactica).
Originally posted by Arquemann View PostCheck the cruise vacuum switch, pull off the line from the cruise servo that goes down and into the cab. It should hold vacuum, if it doesn't, try lifting or wiggling the brake pedal.
