How much do our car's roughly weight with full tank and/or w/o full tank of gas? j/w
Weights...
Your cars curb weight is a little under 3700lbs, maybe even below 3600 just barely since you are carbed. In 86 they added SEFI and that brought all the cars to above 3700, mine being that absolute minimum was 3708 lbs.Last edited by Blaze86Vic; 03-19-2007, 04:08 AM.
Empty weight is 3475 for your car ('81 LTD Sedan).
I think gas weighs about 6 pounds per gallon, so add about 110lbs for a full tank.
With the sound equipment and sound deadner you have, you can prolly add another 150lbs.
It prolly actualy weighs 3700-3800lbs + your weight.1990 Country Squire - under restoration
Just think, a TC is even heavier! Curb weight I believe is over 4,000lbs dry!1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
For comparison, I have some published curb weights for newer panthers here:
Tiggie, is that Ford's specified curb weight for 1981 LTD Sedan?
Mind if I add it to my site?-My Homepage, Panther info & FAQs-
My Mint 96' Mercury Grand Marquis LSE -
Modifications
Click My Merc for more Pics!
Yes it is. As well as the 3708lbs for my 86 Base model.
Originally posted by OVERKILLJust think, a TC is even heavier! Curb weight I believe is over 4,000lbs dry!
Curb (kerb) weight is the total weight of a vehicle with standard equipment, all necessary operating consumables (such as motor oil and coolant), a full tank of fuel and not loaded with either passengers or cargo.
my car is 3832 curb weight. 4000+ with me in it.
Stock 91 Merc GM GS 5.0L EFI, AOD, 2.73 Open diff
Current Best 1/4 Mile 17.175 = 165 RWHP 190 Engine HP
http://www.supermotors.net/vehicles/registry/15193
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
3690 on my CV. :evil:
http://autos.msn.com/research/vip/sp...quis&trimid=-1
Let me re-phrase: It's over 4,000lbs without me in it.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by drock96marquisFor comparison, I have some published curb weights for newer panthers here:
You can add them, just give me some credit . I attached a list of the Box weights, I am missing some of the later ones especially.Attached Files1990 Country Squire - under restoration
Thanks Tiggie
Did boxes have all steel body panels, or were some (ie hood/trunk) alumium?
The weights seem very low - considering the chassis remained so similar, and body components were (or at least I think were) heavier, it seems odd that they could weigh in less than 92-97s (which had aluminum bumpers, composite bumper covers and header panel, aluminum decklid (95-97) and hood, aluminum and composite upper engine components, etc.)-My Homepage, Panther info & FAQs-
Modifications
The weights seem very low - considering the chassis remained so similar, and body components were (or at least I think were) heavier, it seems odd that they could weigh in less than 92-97s (which had aluminum bumpers, composite bumper covers and header panel, aluminum decklid (95-97) and hood, aluminum and composite upper engine components, etc.)1990 Country Squire - under restoration
