Truck 351W Cam Specs
    I searched both the site and the net for this, to no avail.
    What are the cam specs for a non-Lightning '90 351W truck engine? The 351 I bought a few days ago (thanks again, Ted!) has a cam in it already, and I was thinking that if it's a decent cam and in good condition, I might just run it and put off buying an aftermarket cam till later. Thoughts?
    Thanks guys.
    --Nathan
    The only thing I can find on FTE for the non-roller truck 351W cam is:
    .206 intake, .221 exhaust @ .050
    .440 intake valve lift, .450 exhaust valve lift
    115 degrees lobe separation
    You might PM StangMan on ford-trucks.com to verify where he got this information. I really can't say if it's correct or not.
      Thanks, Tiggie! Seems like I can always depend on you to come up with the obscure information I need...lol
      If those specs are right, shoot...that's not a half bad cam. I wouldn't mind using one like that one bit.
        No prob... cam specs always interest me so I am always eager to do a digging to find some numbers!
        It really doesn't sound half bad for a street cam.
        I am PM StangMan if you need me to.
          Yeah, if you could send him a PM that'd be great since I'm not a member over there and I kinda hate to join just for the purpose of doing that and then never post anything.
            I sent him a PM. I'll let you know when he responds. It looks like he was last active about a month ago, which means we should hopefully get an answer. I've sent several PM's on there and they haven't even been read by the recepient over a year later.
              Okay, sounds good. Thanks.
