Ok it started doing this today in the wagon. I get in the car after I turn it off and start it up and it fires then dies right away. Then from the tank I hear a woo sound, different from the fuel pump sound you hear when you first turn the key. It will keep doing this till I hold the gas down for alittle bit then I can put it into gear and be fine. It did this several times in a row this afternoon as I as running around town. No matter how long it sat, in some cases just a minute or two. Now that sound almost sounded like air or something. I have 3/4 of a tank so it isn't cause I am running low.
Thoughts??
Thoughts??
