is 75mm too big to fit on the explorer upper? I found one on the lightning forums.
75mm lightning EGR too big?
75mm???????? Must be hogged out then? The opening on the intake is 10mm smaller (approx) than that, so you'd have a pretty big "lip", which would definitely cause some reversion around th TB area and possibly cause idle issues. It would also impede flow.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by mrltdIt's probably a mustang one anyway. I do not think anyone made a aftermarket TB for the 93-95 lightning.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
