Manual Transmissions Revisted
    I saw another 80's F-series on eBay last night with a manual trans and it got the gears turning in my head so to speak. Granted a truck transmission won't shift as smooth as a T5 it will hold up to more power without needing any upgrades. I looked around an the trans is a mazda built M5R2, also used in the thunderbird super coupe. Both the super coupe and F-series trucks can be found for cheap when you look around online.
    If I remember correctly freshmeat blew out the rear in his car, but the F-series and SC use 8.8 rears so I should be safe to assume a box rear will last for at least some time.
    I am looking at the gear ratios right now, and I would bet that I could use my 3.27 rear and still get awesome acceleration, something compareable to swapping it out for a 3.55?
    The SC engine or 302 out of the F-series would also be useful for swappage...
    -Matt
    Update:
    Shifter location on Transmission makes the truck trans more desireable.
    M5R2 From Truck
    M5R2 From SC
    -Matt
      Could the shifter location simply be changed from the tailshaft to the center? If so, I imagine the gearing in the SC trans would probably be better for you.
        Shifter location on the truck would be worse, it would come up right in front of your radio and heater controls. you'd be reaching over quite a bit to shift. Truck trans would most likely also have granny low 1st gears.
        If you have bucket seats the shifter location for the SC M5R2 would be perfect.
          With a truck style shifter I think it would be ok, compare the depth of the dash on the truck with that of one out of our cars.
          The SC M5R2 with its shifter would probably fit well too.
          -Matt
            Jusdging by that pic of the truck, I would think the SC trans would be a better bet. How is the strength of the M5R2 from the SC?
            Nick
            88 Colony Park LS
              When I was reading it was said that ford used the M5R2 in the supercoupes over the T5 because it could handle the torque better. The guys on TCCOA know about T5 vs. M5R2, time to head over there.
              -Matt
                The sc trans got hydrolic clutch setup. hate that shit
                1999 CVPI
                Old Rides
                1988 Ford Mustang GT (trickflow stage 1)
                1989 Mercury Grand Marquis LS (5.SLO)
                1989 Ford Thunderbird SC (3.8 Supacharged)
                  I believe both the SC trans as well as the Truck trans are both hydrolic, aswell have an internal slave cylinder.... it appears as what gadget was saying that swaping the mounting points of shifter and tailshaft section. it also appears that the SC trans tailshaft is longer.
                  1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
                    I have looked into this swap, well, manual trans.
                    I am actually going to buy a Tremec TKO with my tax return. The F150 clutch setup with the hydralic is a good setup. I will have to see if the firewall has enough space to mount the F150 master cylinder.
                    Stay tuned.
                      This website maybe posted on here somewhere but it should be in this tread its well suited. gear ratios of Ford tranys both auto and manual
                      http://www.vibratesoftware.com/html_...in.htm#5%20Man
                        Truck rear carriers are beefier and used 31 spline axles. MUCH stronger than a box axle. SC used an independant rear setup. I don't know much about it.
                        A 2 door wieghs in quite a bit less than a wagon, and has a lot less over the rear, so it will probably last a bit longer.
                          The 8.8 axle is a VERY strong rear-end, the weak link in the assembly is the 28-spline axles. The trucks use a 31-spline carrier, which is, as mrltd mentioned above, much stronger.
                          With a box, the numbers are going to be different, but with a Mustang, typically anything much over 300RWHP, we like to have the upgraded axles and carrier. The 31-spline stuff in "Mustang Land" is stronger than the stock block by a wide margin, and I know a couple of guys making well over 500RWHP with the 31-spline stuff, making routine passes down the drag-strip without issue.
                          The SC and Cobra rear carriers are still 8.8's, but they use half-shafts instead of axle tubes. They are completely different from each other, but are both 8.8 IRS. I am scoring a diff cover off of one of them this summer because they are aluminum and "girdled" so they look really sassy
                          1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
                            Explorer's also use IRS... I have a nice big aluminum cover off of one sitting in the shed.
                            Another wagon had an issue with the 8.8 rear. It blew the pinion and carrier out the back of it. This is a 300+hp 302 with a wide ratio AOD behind it. It blew on the 1-2 shift.
                              Could an axle have twisted, binding the carrier, causing the caps to fail and the creating the resultant carnage?
                              Yes, the newer Ex's have IRS, the older ones were a straight-axle 8.8, I used to have a '97.
